1 - 13 of 13 Posts
aftermarket gauges
so i bought a tri pill pod for my focus svt and was wornding what gauges to buy as oil, airfuel and so on . next spring Im getting powerworks so boost is one what other two should I get.
air fuel, egt temp, boost vac
no need for an oil guage really, you already have temp and pressure and im not so sure egt is needed to much for a supercharger.
The pressure one isn't "real" oil pressure I thought, it's just what the computer believes to be the oil pressure. I wouldn't rely on that one alone.
i just bought a AEM uego A/F wideband...that will nicely take the spot of my shitty narrowband A/F gauge. THen i have a boost gauge...those two are a must
get a wideband, oil pressure, and boost. those are the big 3
Most people agree on getting a boost guage and an AFR guage. But that last spot seems to be split between EGT and oil pressure. What are the pros and cons of each?
FF #1 Most Wanted
I agree.
Whatever you do, don't install the boost gauge until you get a FI installed.
Across the Pond
Since I'm going turbo, I'm going to be using an EGT Gauge to fill my third spot in my pod. With the SC, I think oil pressure gauge would be of more use to you.
1 - 13 of 13 Posts
