1 - 2 of 2 Posts
I have 2014 Hatchback with the Sony 9 speaker sound system,I'm upgrading the stock sub and amp in the hatch to 2 12's and 2000watt amp..can I use the existing stock wire going to the stock amp to wire my subs and amp? Or do I have to run all new wire?
You must run a new power and ground wire. 4awg minimum. You can likely tap into the stock wiring for the signal to a LOC or into the amp (if it has high-level inputs).
1 - 2 of 2 Posts
