1 - 6 of 6 Posts
What color is the wire that goes to the 02sensor for hook up on a AF guage? I have to hook it up between the computor and the 02sensor connector. Thanks for the help...
what are you trying to do?
Which A/F gauge do you have?
br/o/stang
I wouldnt splice into the factory o2 for a wideband, you should be using the separate o2 it comes with and a separate bung.
If youve bought a narrowband it wont be all that useful for WOT tuning..
The innovate one you can tap into the wideband sensor and run it to a regular o2 lead and sort of trick the o2 sensor into thinking there is a regular o2 in there but its kinda tricky and IMO its a very advanced thing to pull off.
Im just going to run both, the one the car already needs and then the wideband seperate.
is that what your doing?
Boosted HB.
I've always ran two different O2 sensor with my cars not running EMS.
1 - 6 of 6 Posts
