1 - 4 of 4 Posts
I did a search and I have decided to order the AEM CAI. Just to make sure I know what im getting:
The filter is going to be down by the grill.
It has a hole pre-cut and tapped for my MAF sensor
http://focus.c-f-m.com/index.asp?PageAction=VIEWPROD&ProdID=142 thisis the one Im looking at. (there is only one right?)
Do I need to move the battery or anything?
Thanks for any replies. I want to order it on monday
WhiteSTguy
you need to remove the battery to install it. and it's more down by your foglight in front of the wheel well
i hope some of these images will help you out.
I have no problem R&Ring parts. I just wanted to know if anything needed to be moved permantly. Thankyou very much for the pics. helped alot.
I used to drive this
Nothing permantly. When you say "move the battery" do you mean relocating it? Don't need to move the battery, but taking it out for install makes things easier. I've read some people installing without taking battery out. Good luck with your purchase. It's a nice piece.
1 - 4 of 4 Posts
