1 - 2 of 2 Posts
Thanks for checking this out. I have been contiplating which direction I wanted to go with my fofo and I think I finally decided I want to set it up to be able to handle the dirt fire roads and access roads, as well as handle the twisties on the ride up there. I have been doing allot of climbing outdoors lately and my fofo could handle most of the dirt roads that I have come across so far. I also want to have a nice ride when I am going on the long trips to CO and CA and such.
So does anyone have any suggestions? I was thinking about an adjustable set that I can firm up when I need to, or add some mush when traveling on the freeways. I don't want to drop it because of the clearance. Thanks for your help!
Tires are just as important if not more important when you get on rough roads. Increased sidewall height is worth considering as well. Some 195/60-15 (or 205=55-16) would be better than tires with lower profiles. Lower profile tire tend to hop and skip especially on wash board roads. When I rallied, I always used a "70" aspect ratio. Higher aspect ratios may not afford as "crisp" handling as a lower profile one but in the long run they'll ride better too. If your suspension is stock,
I suggest replacing your shocks with some KYB GR2's. They're a cheaper quality stock ride height shock with good damping and rebound characteristics. Really firm shocks (and/or springs for that matter) do not hold rough roads well, especially at slower speeds.
1 - 2 of 2 Posts
