I never found anywhere that was easily accessible when I was running power wire for my sound system. I ended up unbolting the fuse box and drilling a hole straight back through the firewall sort of in between the clutch and brake pedal.What is the usual spot for manual cars?
there is a rubber grommet that comes out the driver door jam, you can then run the wire under the fender up to the fuse box or battery.Well that's annoying. So is there no big grommet through the firewall near the fuse box? If not where do all the wires between cab and engine go?
