1 - 1 of 1 Posts
I have a 2011 S that I use for commuting 2hrs a day. I NEEDED to have cruise control and followed this thread (Installing Cruise Control on 08-11) to find out that I could replace the wheel and get it turned on at the dealer. DONE
What sucked is that I didn't have the stereo buttons. Not a huge 'need' but obviously they're nice to have since they're already sitting on the steering wheel.
I tried to see if the dealer could turn those on at the same time as the Cruise, but after "trying for 2 hours" they told me it was IMPOSSIBLE.
Well....they don't have FORScan, but hey I do!
After for legitimately trying for two hours, I was able to get it. I won't walk you through the process, instead I'll make it super simple.
On line 727-01-01 in the ACM, my As-Built WAS 0040-D08B-E0AB
With working Steering Wheel Controls, it is NOW 0040-08BE-063C
If you simply change yours to read like that, it should work perfectly. You must make this change under the "ACM As-Built" Make sure you save your as-built info first thing just in case you have an issue(but you shouldn't)
I've been using FORScan for about 5 years on a 2013 F-150, and now a 2017 F-150 along with the Focus now. Very thankful for it. FORScan is a free software found at FORScan.org and you'll need to look in the FAQ's on the FORScan site to find out how to get a (free) extended license.
This is the adapter I use. Whatever you get, make sure it has the high/low switch
1 - 1 of 1 Posts
