1 - 3 of 3 Posts
Hi Hang,
I just moved up from my 2006 Focus to wife's ex-2014 Focus with the base 4.2" SYNC (we just purchased her a brand new 2018 Focus SE). After driving her new ride, I was interested in adding a backup camera to the 2014.
After perusing the 'net and this site, it appears that I can enable the backup camera functionality in SYNC using FORSCAN and feed in the signal from an aftermarket camera using a SYNC extension harness with a camera input. Is this a correct assumption?
This is the extension harness in question:
https://www.amazon.com/OCSTAR-Connector-Camera-Harness-Extension/dp/B07G5BV38Y/
EDIT; Or do I want this cable?
https://www.4dtech.com/ford-camera-input-harness-for-sync-1-4-screen/
Here is a camera that looks reasonable; has anyone had experience with it?
https://www.amazon.com/dp/B071Z9FH84/
Thanx in advance for any insights.. :)
Interesting. I though with the 4.3” screen you needed a module to allow video/add a camera to the stock screen.
I was looking at the NAV-TV unit - https://navtv.com/products/NTV-KIT593/4-uni-cam-kt2-for-ford.html - but it looks like my screen is not compatible (has to be proper model and have 75ohm resistance between two pins on the screen).
What are the other options? Do I buy a used screen that should be compatible then buy the module or is there a way to reprogram?
Already bought a camera that replaces the trunk handle, just trying to figure out the best way to connect without buying an aftermarket radio.
Thanks!
- Dan
1 - 3 of 3 Posts
