1 - 4 of 4 Posts
I'm Back!
I was wondering if this is possible? My focus is an '03 that IS pre-wired for factory fogs. Can I hard wire in my aftermarket fogs to this existing wiring? (of course grounding the fog lamp seperate to the frame) and use the "Independent Fog Lights" http://www.focusfanatics.com/howtos/foglight/to supply current to the OEM wiring thus making these fogs function when the parking lights & head lamps are on? OR am I totally wrong! Thanks in advance [thumb]
I'm Back!
Discussion Starter #2
evening BUMP for the after dinner folks [thumb]
I wired in HIDs with no problems. Took out stock fogs. I've used two other aftermarket sets of fogs with stock wiring.
if you are going to use the factory wiring harness for the fogs but don't have fogs from the factory you will need a few things. the oem switch for cars with fogs, the relay, and probably the fuse. but to answer your question, yes.
1 - 4 of 4 Posts
