Gave this topic a new title/thread so others might see it. I have a plain jane 2016 SE. The DTC transmission shifter only had PRNDL - with "L" being low. Using an OBDLink MX and FORSCAN (you can also use FOCCCUS), I added Sport mode (PRNDS).
Now my shifter only has the button to enable hill descent control (made useless by adding sport mode).
So, when surfing around, I saw Merillin's post on swapping steering wheels.
https://www.focusfanatics.com/forum...-se-dct-paddle-shift-steering-wheel-swap.html
Just like his SE, my column wiring harness had all the wiring. So, I bought a 2017 Escape steering wheel with the paddle shifters and swapped it. VOILA! I have functioning paddle shifters.
Merillin had an issue releasing the airbag. If you use a pick instead of a screwdriver, it comes off like a breeze. It fits directly onto the new wheel. I swapped the wheel including reconnecting the airbag in under 10 minutes. The only tools you need are a pick and a 24mm socket with a ratchet and an extender.
Now I have a leather steering wheel, sport mode and paddle shifters. Wahoo! Thanks Merillin!
