I'm in the process of replacing the front struts on my 02 ZX5. Long story short, while trying to reassemble the passenger side knuckle/strut assembly, I managed to pull the axle out of what I assume is the carrier bearing. The boot pulled apart from where it's clamped and the lube drained out on the floor. Axle is still fitted in the hub. Hub/brake/axle assembly is drooping down. I decided to quit before I took a hammer to things I shouldn't.
Can it be re-assembled, or should it be replaced? What's the procedure for both? Had the Focus for awhile, but FWD maint is pretty new to me. I had no obvious problems with the axles/cv/bearing before this.
