1 - 9 of 9 Posts
After searching both sites I didn't find anyone with my specific problem. I have a 02 sedan. The ac has a low pitched squeal when on levels 2 or 3 but not 1 or 4. It sometimes goes away when moving but comes back when stopped with the brakes on. It does it when on ac or full ac with the circulation selected too. It sounds like it's coming from inside so I don't think it's the compressor or belt. Any thoughts?
Perfect! Thank you. Not sure why that didn't come up in my search
I had blower motor squeaking, there were leaves in the fan. Added a cabin air filter to prevent that from happening again.
2004 Focus Wagon, Zetec DOHC, Auto
That was my issue too. I oiled the motor and cleaned all the leaves from the fan and also from the back of the evaporator coil...everything smelled and worked better after that.
I didn't put in a cabin filter because I knew the plastic clips on the cowling would not stand up to the filter being replaced on a regular basis. So, I cut out a piece of window screen I had and fit that onto the placeholder in the filter slot. Been fine since.......
w/ my magic bag
All of the above^^^^^^^^
Thanks for the info everyone. A cabin filter was on my list to check. Ill make sure to clean everything out well when I oil the fan
Bought a filter from rockauto; they and amazon had it listed as "fits my car". Opened the cowling and filter was too small. Any chance someone knows a filter part number that will properly fit?
Yeah Felix, my cowling clips had been butchered by PO. Funny, I never noticed until the day I went to open it up. Repaired/replaced them using misc hardware.
Sorry Marde...I don't know the filter P/N. When I look mine up I get several different filters shown as being the correct fit, so I dunno.
For unplugging the evaporator drain tube, I have used this process: http://www.focusfanatics.com/forum/showpost.php?p=4860302&postcount=16
When my blower started squeaking I took this cleanup a step further. I went in through the blower housing and did a major cleanup on the mulch pile of leaves behind the evaporator. I used the same wet/dry vac with the heater hose attached. After removing the blower and resistor block, I used a mirror and flashlight so that I could see the mulch pile. By snaking the heater hose in there I was able to suck it out. What a difference it made!!!!!
1 - 9 of 9 Posts
