1 - 2 of 2 Posts
so i have a 2001 ford focus wagon and the the ac turns on but after vacuum it to recharge it since it was blowing some cold air but not a lot the ac will make engine die if i try to add anything to it wanted to do a leak test but it wont let me the vacuum held at 30 lbs of Mercury then in 20 mins it dropped to 20 on the low side any help would be great
You just DID test it, the pressure should not drop at all, you likely have a slow leak and wasted refrigerant trying to charge it up.
1 - 2 of 2 Posts
