1 - 8 of 8 Posts
IM NEW TO THIS SO I WAS WONDERING IF ANYONE CAN HELP ME WITH MY 2004 SVT.. MY AC IS BLOWING BUT NO COOL AIR IS COMING OUT AND I DONT HEAR THE COMPRESSOR ENGAGING.. I CHECK THE FUSE UNDERNEATH THE DASH AND IT SEEMS TO BE GOOD. I ALSO KNOW THAT IT HAS FLUID IN IT.. WHY WONT IT CLICK ON ?? PLEASE HELP [mad] [???:)]
TURN OFF YOUR CAPS!!
You probably are extremely low on freon. The compressor won't come on when you are that low. You need to get it checked for a leak.
Sorry about the caps well i checked to see if i was low on freon but i wasnt.. and i also put atlittle in to see if it would leak but it didnt ... Theres got to be a fuse or relay some where i also checked the fuse under the dash and it was good .. Is there a relay or something else i should look at before i determine its my compressor ?
if your refrigerant is low, the compressor won't kick on. if the compressor won't kick on, it won't take a charge. usually, you can jumper the wires on the low pressure switch to get the clutch to engage so you can fill it. that's standard procedure on pretty much every a/c system.
lucas.
A/C
You probably have a cracked evaporator core. I have had to have my A/C recharged 4x within the last 2yrs. Finally the dealership realized what the problem was and they are replacing my evaporator core. Apparently its a real problem with the focus.
1 - 8 of 8 Posts
