I bought a 01 Focus DOHC with several problems and have solved most everything. It was hit in the front and looks as if the drivers side control arm has been replaced. The ABS light is on and cant seem to find a problem. The repair manual says to check output voltage of the pick-up at each wheel. Hooked up everything but no voltage. How fast do I need to spin the wheels? I tried the turn key hold the trip odometer, lot of numbersI have no idea what that’s telling me. I can get a OBD-ll scanner but almost sure that will not read ABS codes. Any suggestions
