Hey guys,
I replaced my rear shoes and drums today. Everything went fine (I thought) but when I went to drive home my ABS, traction control, and e-brake lights were on. E-brake only comes on while car running, goes out after a couple seconds when key set to on just before cranking.
I put it back up on the jack and double checked the abs harnesses were indeed plugged back in. Im sure the E brake is good.
What the heck is going on. Only thing I can think of is I sprayed brake cleaner on the backing plate to clean it off, didn't consider sensors as this is the first car I've had with ABS or Traction control.
No codes found by my sct scanner. Battery disconnect didn't fix it either. Fluid level just barely under the full mark....
Did I F something up with the brake cleaner?
Help please!
Help please!
