1 - 2 of 2 Posts
Got error codes from the abs: C1145, C1234, U2023. Tried replacing the right front abs sensor but stil get the same error codes. It is possible to test the output voltage form the abs module ?
The wiring to that sensor being bad will make the same code.
WHAT output voltage?, the ABS output is hydraulic pressure.
1 - 2 of 2 Posts
