1 - 12 of 12 Posts
Hey all...would anyone have the location of the ABS module in a 2002 SVT???
I've got a "low Voltage" error and it keeps cutting in and out...driving me crazy.
I need a replacement module...anyone got one laying around??
Thanks for your time.
Resident Curmudgeon
It is located directly under the engine compartment fusebox.
Are you generating a CEL or an ABS warning light?
The Librarian
If you mean the computer/brains portion of the ABS system, it's located dead center underneath the console, just aft of the shifter.
The Airbag computer is also stuffed under the console in the same area.
Resident Curmudgeon
Good catch Reverend...
I ALMOST..almost asked "which one", but rolled the dice.
Bad moderator, BAD! [chair]
Discussion Starter · #5 ·
ABS electronic module location...
Would anyone know where in the car this module is located??
Would anyone have part numbers for it??
Thanks All.
Edit: I posted with the answer for where the airbag control module was, my bad
if you are looking for the item that has all the brake lines going to it, its behind the battery against the firewall below the engine bay fuse box.
Discussion Starter · #8 ·
Thanks...mutch appreciated!
Discussion Starter · #9 ·
I am getting the ABS and the Traction Control light coming on and off. When I check the codes it says passenger side rear sensor so I replaced both the sensor and the pick up ring. All was good for a while then it started again and now with a "Low Voltage" issue...thought it maybe the power supply on the ABS module circuitboard going away.
I do have 194,000 kms on the car...!!!
Any and all info would be appreciated.
The Librarian
Chk the +12v supply cable to the ABS first, it runs more or less under the airfilterbox, and tends to be worn off by the filterbox, its easy checking, just remove the filterbox, and look for some cables that runs underneath it. My guess is that tou will find a red one in the bundle of 3-4 cables with worn off insulation....
Discussion Starter · #12 ·
I checked all the wires going under the Filter box and no wear on any...hmmm would it not blow a fuse???
Still trying to deal with this issue....
Thanks for the info.
1 - 12 of 12 Posts
