1 - 6 of 6 Posts
im very intrested in getting a turbo.
i only plan on running maybe 8-10 psi
my main question is on tunning. ther is no dyno near me that i know of.
would a "mail order" tune be safe to run.
what kind of price am i looking at for a basic turbo kit.
mail order tunes would only be safe if you were to datalog with a wideband O2 sensor, and have the tune adjusted until it was right. nobody can provide you with an off the shelf tune that will be completely safe. you can get a base tune that will allow you to make a run or two for datalogging, but then it needs to be adjusted.
so with low psi, the main concern i will have is with the air/fuel ratio ?
air/fuel, spark timing, etc. there's a lot that goes into a tune, and if you don't want your engine to blow, you need to do it right the first time and get dyno tuned
Discussion Starter · #5 ·
thats my problem. the nearest dyno is at least a 3 hour drive away.
would a base tune be enough to drive the car for that long until i get to dyno ?
1 - 6 of 6 Posts
