I just had a quick question about the Clutch Position Sensor Mod I've been hearing about. Apparently if you disconnect the sensor from the clutch pedal bracket it will (if I understand it correctly) prevent the ECU from pulling the spark timing while you shift. I did try this, and I did indeed feel the car respond better while shifting, and I could be wrong but I also felt as if the low end torque was a tad better. The question is this: what would be the harm in leaving this sensor disconnected? I mean, my worry is that if Ford designed it to pull timing while shifting it must serve a purpose, but then again, being a Ford it might not. I just don't want to drive around with it disconnected if I'm gonna start knocking or pinging or fry a coil or something. Would there be any drawbacks to this, or am I being overly paranoid?
