1 - 5 of 5 Posts
There are no bushings to buy with that kit. You can just install, the only work to existing components necessary is to cut down the existing bumper stops (they provide instructions).
Depending on where your alignment is you may need some camber adjustment plates (front) and camber bolts or adjustable arms (rear).
When I fitted this kit I knew what alignment specs I wanted and fitted adjustment plates and adjustable arms at the same time.
alright sounds good.
i most likely won't have any problems thought correct?
my car is currently decomissioned until i get these parts, my right front wheel is rubbing on the wheel well when i take left turns and go over bumps anything faster than like 10-15mph. these parts still haven't shipped. i'm getting pissed. ordered them 2 weekends ago
Trump 2016
you should have no promblems just make sure you find an alignment shop that knows what there doing otherwise you will be eating tires
alright thanks. what about strut mounts? i hear some places like for you to get new ones? my brother ran into that problem
1 - 5 of 5 Posts
