1 - 4 of 4 Posts
Hey Guys,
Needing some help on a few more question. I have a 2000 Focus Kona Edition 2.0 16v with a manual tranny.
First,
What weight of synthetic transmission fluid does the car use? What brands would you guys recommend? Can you just drain the Transmission fluid and put in more? Or do you need to dis-assemble something first? Is there a filter that needs to be changed? If so, how hard is it to do that, do u need to dis-assemble anything?
Second,
Where is the cabin air filter? I’m assuming all it does is filter out the dust, etc from the cabin? Can it restrict the air flow from the ac/blower any? How much do the cabin filters usually run?
Thanks!
Focused Focus
You will have to look and see if you have a cabin filter to know if you have one. Your car probably doesnt being the age it is. You can just drain the tranny fluid and refill it with Motorcraft XT-M5-QS. No filter there either. Sorry, forgot. your cabin filter is located under the right hand wiper cowling if you have one.
1 - 4 of 4 Posts
