Well, first and foremost, heres what i have in mind :
1. Upgrade speakers - probably Alpine Type-S all around
2. New wiring between amp and speakers, and new electrical wiring (I already have wiring for an amp installed, but its a very small wire, i think 10 gauge)
3. New 4-Channel amp to power speakers - Not sure what im getting yet but nothing very expensive
4. Deadening in doors, and other misc places
5. Possibly a small sub, depending on if i like what i hear from the Alpines as far as bass
6. Install false floor, in the trunk, and install the amp in a hole (you know what i mean), possibly taking the cover from the amp to allow the internals to show
7. Install computer fans for cooling around the amp, and maybe 1 or 2 of those ricer light bars
8. Build a cover from plexiglass to protect amp
My questions :
1. Are those aftermarket battery terminals used as the regular ones, and is there any advantage ?
2. What thickness MDF will I be able to use between speakers and sheetmetal without any clearance issues ?
3. What can I cut plexiglass with and buff with?
4. Will computer fans be sufficient enough to keep an amp (Around 250 watts RMS)cool in the environment I plan to put it in ?
5. How much deadening mat should i get? (I might do the trunk also if i put a sub)
6. In your opinion is the mounting idea cool or a waste of time and money ? (I know that its not original, i saw it on Pimp My Ride like 5 years ago, and thought it was cool)
7. Can someone point me in a direction as far as good crossovers and high pass filters (brand and where to buy), or wether i should get one of those sound processors that is multifunction ?
I appologize for the long post but I tried to make it as organized as I could. I will appreciate any feedback. And i will probably start the build in early spring for weather reasons.
Thanks.
My questions :
Thanks.
