I have an 09 Focus SES coupe 5spd manual. Just recently I noticed I was getting some front end suspension noise usually when going slow and going over bumps you hear it more than when you are at high speeds or even traveling normal speeds. I checked everything end links, tie rod ends, ball joints, cv boots, etc. Everything seems ok to me I did see the sticky about the tsb on the end links and other things causing front end noise. The car has almost 65K on it and if that stuff wouldn't be fixed for free I will just change it myself. I am leaning towards just changing the end links since I know that they are problematic on our cars. The one question that I have is while I was checking everything I also inspected the front sway bar bushings and figured it might not hurt to change them as well but the problem is I cant find them anywhere only the rear ones. I figure those two things should stop my noises at low speeds. The other issue I have been having recently is that I switch between winter and summer wheels and tires and I have the winter wheels and tires on now and the winter tires are noisier than the summer tires but recently only at high speeds when I turn to the right I get a loud humming/vibration noise. I checked the wheel bearing and everything seems nice and tight with no play. So basically I am just looking for a few suggestions on these few things to see what my next move should be.
