1 - 15 of 15 Posts
i have been reading about the xcalibrator and other tunings in the forums, and i was wondering if doing this to a stock svt would require any other modifications to the transmission or drive train? would i be good to go by starting out with a tune like this with no other mods involved?
Turbo!!!!
I was told when I first got my svtf that a tune was the first thing I needed to do....I have yet to do it
i was curious because i am not a mechanic nor do i really know what changing one thing will do to effect other areas. i dont want to do a tune or anything else and have it tear up something stock that should have been upgraded.
Turbo!!!!
I'm pretty sure it just changes the engine codes to modify your speed and rev limiters allows you to shut down the traction control (if you have TC) and a few other things . I know their are SC kits that don't require any internal upgrade and those come with tunes ,but their are guys on this forum that can give you specs on each tune and what it will do for you. At the top of this thread their is a post on tune reviews.
Discussion Starter · #5 ·
yeah, i was reading those. my question is mainly if a tune can be done alone without any other immediate upgrades.
Yes. U can tune your car wiyh no other modifacation no prob. All tuning does is optimize what u have.[thumb]
Discussion Starter · #7 ·
cool. i may start to sound like a moron here, but will i need a laptop for this?
no. you only need a laptop for data logging. Flashing your car is very quick and easy, go for it you wont regret it.
You don't even have to go into all of that. If you get a flasher (SCT Xcal2 or Diablo Predator) all you have to do is plug the connector into your car's OBDII slot (there is a little door underneath the steering wheel- left side), press a couple of buttons, grab a snack and you are done.
I have the tune and it does much more than just change the rev limits. It's about change of drivability by changing fuel curve revs and about 100 other peramiters. Wayne or tom could tell you best about tunes and stuff
FF Affiliate
I feel i have the best tune out there and for sure the tune with the least amount of issues
My tune will gain low and good mid range TQ and HP as well as better idle and with no surg issues throttle response will be better as well as many other things
My tune cost more at 495.00 (Diablo Predator with custom tune )but my customers arnt having all the issues either
WhiteSTguy
Tom - when you get a tune for the 04 svt that kills the tc let me know!
i'm looking for a tune but don't want one till that issue is solved, thanks
- Lee
FF Affiliate
I can turn off the TC on the 04 now BUT because it turns off the ABS with it i wont sell it
I have had good luck with the 04 NON Euro as for turning off the TC
Discussion Starter · #15 ·
thanks guys. i think one of those flashers will be my next purchase.
1 - 15 of 15 Posts
