2003 Zetec
Last summer it worked fine. After summer I pulled the fuse out so that I could run the defrost on full without the AC running and making it drive like crap.
Now when I put the fuse back in the switch will either not light up at all or only light up on the low fan setting, if I turn the fan up the light goes out.
The strange thing is that with the fuse in and the ac appearing off the car hesitates a bit like the AC is running. The only way to make it drive normal again is to pull the fuse..
Any thoughts or advice on where to start?
Thanks
Thanks
