61 - 71 of 71 Posts
Discussion Starter #61
Doubtful, pretty sure the pre-2012 motors were a totally different architecture.
The TB drive motor? The 08-11 is drive by wire
owner: Rebel Devil Customs
Red Devil STedan #1
Project NAS-T
No, I was referring to the engine architecture. I assumed that the throttle bodies would be different, since my understanding is there is not much interchange between the Ti-VCT and the earlier engines. But I could be wrong.
From the video I'd seen earlier, they looked similar. Next time I'm in Pik-A-Part, I'll need to check closer, before I lay down any cash. Thanks for all the replies.
Discussion Starter #66
I have a 2000 ZX3 vin 3 would i benefit with mpg with the 63mm t/b? I fo have 233k+ miles on the engine, doesn't smoke, and can still scream out 5.5k rpm.
Suggestions?
Yours is drive by cable, not compatible
Red Devil STedan #1
Project NAS-T
FF Affiliate
Suggestions?
Would you gain MPG ,HP , TQ no
Dyno tested properly will show no gains from a larger TB
Discussion Starter #69
Hey, hmmm
Red Devil STedan #1
Project NAS-T
Suggestions?
you're in the wrong discussion forum. You're gonna want to head to the discussion forums -> Ford Focus First Generation -> ZETEC Performance (2000-2004)
your car has a zetec, which means that the throttle is operated by cable, not wire. You can still widen the throttle body if you want sharper petal repose, but it wouldn't make sense without a CAI.
Best bang per buck is of course a Cold air intake (CAI) or short ram intake.
Also consider doing a lunch box delete (remove the second clunky muffler).
check out the zetec forums for more on both of these things, they are everyone'e first mod. cheap, easy, and noticeable. Its all downhill from there [drinking]
Sorry to bump this dead horse [hihi] I just posted a 63mm throttle body for sale in the marketplace, was wondering which drive by wire engines it will bolt up to. Thanks for the help
61 - 71 of 71 Posts
