1 - 3 of 3 Posts
Jetsetter
that doesn't look normal, you should be able to find a replacement fairly easily online, I do believe to remove it you remove your interior dome light, then you should be able to access the blot/nut that holds it in place
the threads are broken off. you can get one cheap from a yard or ford.
you gain access to it from your map light inside your car. remove yor map light and you will see one but holding it in place
1 - 3 of 3 Posts
