The easiest way is to drill two holes through your bumper and put as wide and long of a piece of metal as you can fit under the plastic to distribute the load. You can weld flat metal bar to a stout piece of the front end and run it through the grille or bumper by cutting slots out too. Remember to reinforce more than you think as bumping around will wear out your support, especially the farther away from the attachment point.
