1 - 9 of 9 Posts
will a 49 offset be ok on a sedan.....i really hope so and if so what size tire should i use
The Librarian
49mm offset is just fine. [;)]
Is your car lowered at all?
For 215 widths, either 215/40/17, or the stock SVTF size - 215/45/17 will work as well.
The 40 series should be close enough to not have to worry about speedometer error.
45 will be a bit taller, and your speedo will read slower than actual speed.
Discussion Starter · #6 ·
no my car is all stock as of now...just bought the rims..once those go on the the body kit. just want to know if they would work. how far could i lower it without problems?
you could lower it about and inch. here's how my car looks with the eibach pro-system plus and 17x7's. just PS you wheels onto this picture and you should have a pretty good idea of what you'll get.
i didn't install it myself, i had a shop do it. if you get your kit off of the tire rack, and use one of their recommended installers, said installer will give you $100 off. that's springs, shocks,struts, and alignment. personally, i paid $260 for the whole thing. the installation, that is. the kit cost $750. but it was well worth it!
1 - 9 of 9 Posts
