1 - 3 of 3 Posts
I am trying to decide between the BAT/Spax spring/dampner combo but have a question. I have heard horror stories about people who install systems that drop the vehicle over 2" and having allignment problems.
Will I have a problem with a 50mm drop on my car and if so, what can I get to remedie the problem?
you won't have a problem with that drop. but, as with any drop, you'll want to get an alignment afterwards, since just about any alteration to your suspension will throw off your alignment SOMEHOW. what i would suggest with a 50mm drop, though, are some camber adjustment bolts for the rear. the rear is where you will notice the camber change the most, and may cause some tire-wear issues. so pick up a set of camber bolts, and have those installed/adjusted when you take your car in for an alignment. being that you are in alexandria, i would highly recommend talking to carl at the auto shop, in sterling (www.theautoshop.us). hope that helps.
1 - 3 of 3 Posts
