1 - 3 of 3 Posts
i cleaned my throttle body yesterday, with throttlebody cleaner, and now my car idles around 1krpm, and when im shifting(5spd) the RPM falls extremly slowly if reved over 3k if it falls at all. and the 3 CEL codes are:
P0054, P0108, and P2004(had P2004 before cleaning).
any ideas, its driving me insane.
DTC P0606
Odd codes.
Describe what you did for your throttle body cleaning.
Did you get any carb cleaner in the TPS (throttle position sensor)? Did you do anything with the MAF sensor?
Throttle body has a sign on it that states not to use cleaners on it because it will screw up the TPS and remove some special coating that is on there. At least mine does anyway.
1 - 3 of 3 Posts
