Just wanted to address/explain 3 glitches I have experiened so far with the 2012 focus. I have owned the car for about two months, and besides these glitches I have experiened thus far, I have loved it.
1. Cruise control: 3 or 4 times since I have purchased the car, I have noticed that after starting the car, I cannot engage Cruise Control. The only solution I have found was to turn the car off at a red light, remove and open/close the door to cut the power off to sync, and then turn the car back on.
2. Windshield washer fluid: Just experienced this today. I started up the car and turned the A/C on. I then pulled the wiper level to me and the windshield wipers moved but no fluid sprayed out. After stopping at the mall, I checked the fluid and there was fluid in the container. I started the car up, began to drive, and tried it once more and it now shot fluid onto the windshied.
3. I have also experienced this a few times as it tends to happen when I put the blinker on for a split-second or so and then disengage the blinker. When I return it to the neutral position the opposite blinker starts to blink. For example, if I put the right turn blinker on to change lanes and turn it off, the left blinker starts blinking. Only fix I found is to put the opposite blinker back on and then turn it off.
Has anyone else experienced these issues? I should also mention that I have Ford Sync but not the My Touch version. Who should I report these glitches to? I love the car as I'm getting like 39.5 mpg average per tank, but the third issue should definitely be addressed. Has anyone else had any of these issues? As mentioned, all have happened only a couple times (blinker issue has happened about 5 times).
Thanks
Thanks
