1 - 1 of 1 Posts
  1. Yo fellow Focus drivers! I've searched around the internet to find the fluid bleed valve for the EcoBoost 1.0 3-cylinders with a 6-speed manual and I never found it. So I searched for it myself and I found it! I saw that with the Focus RS, you have to remove the air box which seems to be true for all Mk3 Focuses. Then you should be able to look down at the transmission and find a rubber (perhaps red) cap. Take that darn thing off. It doesn't use a wrench to open and close the valve though. In my case, I had to use my fingers and rotate the switch-thing it from it's closed position to it's open position. It's about a 300°-ish degree turn I'd say. Here's a YouTube video that works hopefully!
1 - 1 of 1 Posts
