1 - 4 of 4 Posts
I have a 2014 SE with 63k miles. I was doing an oil change and I noticed a small oil leak on the left side of the engine near the drive belt and oil pan, the drivers side of the pan was clean. I just wanted to get your guys thoughts on what you think it could be? My only guess would be the oil pump or camshaft seal.
Damn, 63k miles.
If you were under 60k I'd say just take it to the dealer. Powertrain warranty sould still cover stuff like that.
Damn, 63k miles.
When I did the 58k oil change it looked perfectly clean, just some bad luck. I bet the dealer would charge close to a $1000 to fix this so I might try a oil sealer, something like AT-205 Re-Seal.
Looks like a timing cover leak. Seems common on our foci, and i just got mine done along with some other work. I hear it is a technical job to do. My labor bill was 1300 plus parts, but that included other things as well.
1 - 4 of 4 Posts
