I am looking to replace the headlight bulbs on my 2014 SE hatchback and am looking for suggestions for a good white light output replacement.
That's what I use. Highly recommend them.I have had good luck with Philips X-Treme Vision, but I haven't actually tried the H11 or used them in my Focus (I had them in my Accord).
Why did you opt for D3S and not another bulb type? There seems to be so many to pick from.I am waiting for my D3S retrofit setup but in the meantime I put in the Philips CrystalVision Ultra. I must say that they are not bad for blue coated bulbs.
I am sure that the X-Tremem visions are brighter but these crystal vision ultras are not dim by any perceptible measure.
H11 bulbs in my old Altima 2 years no problems. In my opinion better light at night. My focus 3 weeks with sylvania H11 brighter than stock. As for wasting money have to disagree in my opinion.There isn't a single H11 halogen bulb on the market that will give you enough light over stock to 1) be worth the money and 2) not burn out absurdly quick.
The two options for more light is to modify an H9 bulb (and still deal with slightly shorter bulb life), or get HID lights and projectors.
I've done it all, and new H11 bulbs are a complete waste of money.
The D3S assemblies I'm talking about are the OEM headlights for the ECE FocusWhy did you opt for D3S and not another bulb type? There seems to be so many to pick from.
$1700! [ohcrap]The D3S assemblies I'm talking about are the OEM headlights for the ECE Focus
http://www.european-parts.net/catalog/product_info.php/cPath/141_154/products_id/1433
not really an HID retrofit in the 'traditional' sense.
I ordered a set of the Philips H11 CrystalVision Ultra from Amazon for $31. They are without a doubt brighter then the stock bulbs, not HID bright but they are about on par with Sylvania ZXE bulbs I had in my last car.
http://www.amazon.com/gp/product/B00480GYSA/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
But then you have to buy a set of decent projector headlights, or retrofit projectors into your stock headlights. You could buy 3+ sets of brighter halogen lights for that price.In my experience, any brighter or whiter halogen bulbs don't last long enough to justify the price. For what you pay for say, Sylvania Silverstars, you can get a set of HIDs from places like DDM Tuning and they'll last MUCH longer.
You don't "have to". I've had HIDs in many cars over the years with no problems. Make sure they are adjusted correctly and you will be fine. Our headlights actually are one of the better ones I've seen as far as using plug and play kits. You still have a fairly decent soft cutoff line and not that much glare, as long as you go with a 35 watt kit and don't get a 55 watt kit.But then you have to buy a set of decent projector headlights, or retrofit projectors into your stock headlights. You could buy 3+ sets of brighter halogen lights for that price.
Yeah, you don't "have to", but you also don't "have" to be the a-hole running around blinding people with their HIDs.You don't "have to". I've had HIDs in many cars over the years with no problems. Make sure they are adjusted correctly and you will be fine. Our headlights actually are one of the better ones I've seen as far as using plug and play kits. You still have a fairly decent soft cutoff line and not that much glare, as long as you go with a 35 watt kit and don't get a 55 watt kit.
