The big gear bearing pulls off with a bearing puller, pressed on. And if the cover going on is not the original you WILL have to resetup the shaft end bearing preloads or you will get noise or tear up bearings on ends of shafts super quick.
The cover may not just slip all the way down that last half inch, it likely has to press tight over the bearing races. As in be 100% sure of parts placement and light whacks with a mallet to seat the cover.
And, looking closely at your parts stack, the big gear (differential drive ring) appears to have the gear on the right actually touching it like the parts stack is not fully settled down in place. Can't say positively as I haven't done one of those yet but as a trans guy from way back you go looking for such things as problems.
Don't overlook that bearing preload issue, it may turn that work into scrap. Special tool needed to figure the preloads unless one is smart enough to make up for the lack of that tool to do it another way. You don't just change covers there, they have to be matched to what you already have.
