1 - 2 of 2 Posts
We have a 2014 Focus which has had experienced Brake Light Faults since it was under warranty. The problem is always solved by replacing a light, but we have replaced three so far. Ford never charges to replace the light, but I find it hard to believe the problem is a string of defective lights. The problem affects both the left and right lights but not the high one.
Anyone have any idea what is going on here?
Try using some bulb grease on the wire contacts if not already doing it. Use long life bulbs. Pull bulbs from socket and pry socket contacts inwards to increase pressure on the bulb base.
1 - 2 of 2 Posts
