^^^ yup.
Just wanted to throw that out for a double check, your reading was exactly what I get when FULL by just pulling the stick after it sits overnight. Looks durn near a quart low.
Confirmed here to be common, so I always ask the "silly" question.
Note the issue for sure, and start tracking in case it continues or gets worse. I know you mentioned not being able to confirm now, that makes future tracking all you can do for certain.
More have drips than use oil, drips seldom are bad enough to affect levels much. Excess consumption HAS happened, so just keep an eye to make sure you're OK.
1 qt. between changes falls into 'normal" range, even though most use much less, so you need to track it well (and have it get worse) to have a case for repair unless leaking.
