1 - 7 of 7 Posts
Just installed fog lights, wiring harness, and switch (with fog lights).
Attempted to actuate fog lights on with foccus. Now, turning on fog lights, dash indicator shows them on, but actual fog lights don't light.
Brand new harness and lights. Used switch. 15a fuse is hot.
Wondering if I messed up something in the programming. What the what?
I've looked through other posts and haven't found a similar problem. My first time using Foccus. Help please
Did you use halogen bulbs or LED? I only ask because I did the same process using LED fogs and had to reverse the polarity to get them to work.
I really could use a little input here, before I start going thru the pinpoint tests from the BCM to the lights. And yes , these are halogen bulbs
1 - 7 of 7 Posts
