Went from 72 yesterday to 40 today and the CEL came on first thing this morning. Went to AZ cause there's not a dealer near enough to me and I knew if the car turned off the codes might go away and the dealer would tell me tough luck. The codes I got back were:
V0109
LOST COMMUNICATION WITH FUEL PUMP CONTROL MODULE
P025A
FUEL PUMP MODULE CONTROL CIRCUIT / OPEN
P0103
MASS OR VOLUME AIR FLOW A CIRCUIT HIGH INPUT
just got home, turned the car off, back on again, no CEL. I'm in IT and I see "turn it off and on again" issues a lot but this has done this 3 times now and the dealer turns me away each time. When it does this the car bucks worse than it usually does and takes 2-3 seconds to shift into 2nd and 3rd, it sounds like it's rev matching every time. Turning it off and on cleared the CEL and made it behave at least how it did yesterday (I won't say better).
Should I waste time going back or since the CEL is gone are they going to call it good? I took pictures of the actron scanner thing because I felt like I needed at least some evidence. They gave me a print out of one of them but said the other two were dealer codes or something, could not print them there.
V0109
P025A
P0103
