OK. I would like to use a larger oil filter on my 2013 Ford Focus. Before anyone starts with “do you think you are smarter than the Ford engineers”, let me just say that I can sight numerous examples where factory engineers have been dead wrong. Anyway, I just want to use a filter with more capacity. From past information on this Board I have learned about some alternate oil filter choices. The factory spec oil filter from Mobil 1 the M-102 has the dimensions as follows.
Height 3.404
OD 2.98
Gasket Size
OD 2.738
ID 2.430
Thickness .226
The filter I was going to use was the M1-204 has the following dimensions.
Height 3.75
OD 3.69
Gasket Size
OD 2.834
ID 2.462
Thickness .20
When I tried to use the M1-204, the gasket seemed to be rubbing on the block, so I put The M- 102 on.
So my question is, have any of you made this switch to a similar size filter as the M-204 on the Focus and am I being overly cautious. If you think or know the M-204 will not fit is there another filter size I can use to get more filter capacity?
Thanks in advance,
kajunman
Height 3.404
OD 2.98
Gasket Size
OD 2.738
ID 2.430
Thickness .226
Height 3.75
OD 3.69
Gasket Size
OD 2.834
ID 2.462
Thickness .20
Thanks in advance,
kajunman
