1 - 4 of 4 Posts
I believe its 150 amps but I called the dealership to confirm and they put me on hold and then someone picked up and said "who are you holding for?" and I said umm you were checking on a focus alternator for me and he goes "oh um yea I think your right 150 amps" so I don't believe he even checked for me. If anyone knows the answer to this question please comment!
Let's try this in the MkIII section to see if anyone knows the spec..
414-02 Generator and Regulator 2012 - 2013 Focus
Specifications Procedure revision date: 06/6/2012
Specifications
General Specifications
Item Specification
ST vehicles
Generator pulley ratio 2.76:1
Rating 90 amps at 650 rpm to 160 amps at 2,200 rpm
Voltage regulator type Electronic internal with generator
All other vehicles
Generator pulley ratio 2.45:1
Rating 80 amps at 750 rpm to 150 amps at 2,500 rpm
The S/SE/SEL/Ti alternator is 80-150 amps
The ST alternator is 90-160 amps.
Focus Preacher
Alternators are bigger than the norm because of EPAS... this thing need a lot of juice when in use.
1 - 4 of 4 Posts
