1 - 1 of 1 Posts
StopTech Focus ST 13-14 Braided Stainless Steel Brake Hose Kit
Today we are installing StopTech's braided stainless steel brake hose kit fitting all 2013-2014 Focus STs. If you like to drive your ST hard or take it racing, than you might want a little more confidence in your stopping power, with StopTech's brake hose kit you can expect an improvement in overall braking performance as well as improved pedal response.
Installation is simple but messy, you can expect some brake fluid spilling out when removing the factory lines. Once installed you will need to bleed you brake lines so you will need another person to help with this process.
Once installed, we noticed an immediate improvement with the stopping power of our Focus ST. If you are into auto crossing, drag racing, or you just like to drive you ST aggressively you may want to upgrade your brakes with this brake hose kit from StopTech.
For more Spool Tuning options of StopTech parts check out: StopTech Brakes | Spool Tuning
1 - 1 of 1 Posts
