I too noticed that on my 2012 SE when I was making the purchase. I just wrote it off as something that a lower-end model would not have. I guess there are two sides to that coin though: having the liner would neaten things up and keep it quieter (negligible) but would also be a pain when you have to change a tail lamp. Popping the liner out, setting it aside, replacing it and making sure it's lined up just so. Another odd thing about the trunk is there is no inside handle to close it. I just use the emergency glow-in-the-dark handle to pull the trunk closed. I don't like pushing the trunk closed because the car is filthy (I need a wash!) and I have also found myself pushing it closed via the spoiler which is a no-no.Has any one else noticed that the interior of the trunk lid on their sedan is just plain bald metal with no liner of any sort?
That is one of the things I loved about the hatchback (2013) I rented before buying a sedan. It has a neat handle on either side of the inside of the hatch to pull it closed with. I'm thinking of adding something like that to the inside of my trunk lid now. I know what you mean about it being too easy to push it closed by the wing, which does not seem sturdy enough to handle too much of that. (Unlike the one on my old Integra, which is pretty solid.)... Another odd thing about the trunk is there is no inside handle to close it. ...
http://www.group1autoparts.com/ford...-lid-and-compartment&part_name=trunk-lid-trimAnybody knows how much is this trunk liner?
Yeah, older Benzes did not either and I had a few of those so I got used to having chunkier license plate frames that double as a handle to close the trunkI too noticed that on my 2012 SE when I was making the purchase. I just wrote it off as something that a lower-end model would not have. I guess there are two sides to that coin though: having the liner would neaten things up and keep it quieter (negligible) but would also be a pain when you have to change a tail lamp. Popping the liner out, setting it aside, replacing it and making sure it's lined up just so. Another odd thing about the trunk is there is no inside handle to close it. I just use the emergency glow-in-the-dark handle to pull the trunk closed. I don't like pushing the trunk closed because the car is filthy (I need a wash!) and I have also found myself pushing it closed via the spoiler which is a no-no.
