1 - 4 of 4 Posts
Has any one else noticed the two holes, 25mm in diameter, in the trunk floor of their 2012 sedan, immediately behind the rear wheels that are only sealed with a piece of tape? Note that there are two, larger diameter holes nearby in the trunk floor that are properly sealed with rubber body plugs.
I suspect someone forgot about the plugs, in the factory???
You could check with the Parts department, and see if you can find rubber plugs called-out for that location. It would be a warranty claim, no issue.
If you are referring to the holes under the carpet right behind the fender well then mine has plastic caps in them.
Montana
Discussion Starter · #4 ·
No these holes are not under the trunk's carpet. They are well inside of the interior side trim in the trunk. The larger holes under the carpet have plugs in them. These holes are to the outboard of the plugged holes and can only be seen from under the car without removing the trunk's interior trim.
1 - 4 of 4 Posts
