1 - 14 of 14 Posts
Hello,
First of all talk about tools,
- A small unsharp knife. :)
- Torx 20 screwdriver
There is small cover just under the head unit.
It is locateds middle of aircondution outlets.
There is small clips at the corners of cover. Use knife for releasing them. (blue circles.)
When you oncovered that, you will see 2 pcs screw which I circled red. Those torx20 screws. When you unscrewed them, you will ready to take out front panel. If you could not, use "unsharp" knife for relasing that spings. Those are located on both side of front panel.
You have to be carrefully because of wiring. Cabling is short. You should have to unplug the socket which is located center of front panel.(red circled below picture) There is a small clip side of plug, when you push that, it will release plug.
Now, you were removed front panel. :)
You will see naked headunit and screen. :)
There is 6 pcs screws for fixing headunit. Two of them for headunit, 4 pcs screws for display.
One more time you have to be carefull when you are taking them because of wiring.
Display has a only one cabling socket on low level display.
At navigation unit there are navigation antenna cables too.
There is two different socket behind of head unit, but only one of them is using.
And antenna cables are balanced cable. Those are just for radio.
Head units are same at all models. No need to change when you are upgrading to navigation unit. You will need navi antenna cabling, front panel (actually no need that, you may use voice control or steering wheel controls) and display. Display including navigation.
Part numbers are;
5" Navigation + display unit
AM5T-18B955-DG
Front panel ;
AM5T-18K811-CD
BM51-18835-BE3JA6 (plastic cover)
Wow those are some good pics! Thanks
Does anyone have the Speaker Colors for the front and rear speakers?
merruse Are you actually in Turkey? I would love this for my SE, but does it still have SYNC? And I wonder if that works here in the states
Merruse, do you have any info on the the wires in the harness for the stereo?...
In particular which are the speaker wires, -VE, earth, etc...
I am looking to add an amplifier and replace my front speakers.
Thank you.
Thank you.
this is actually very easy. what you will do is use a Line Out Converter
http://www.crutchfield.com/p_142SLC4/Scosche-SLC4.html?search=line+out+converter
Use these wonderful instructions:
http://www.ehow.com/how_5076523_connect-stereo-line-out-converter.html
Sorry you still need to know which wire is the left speaker and which is right speaker, however I am sure you can either trace the wires from the speakers in the door, or just find out the color of those wires and look for them coming out of the harness going into the head unit
chea!
Thanks for that mate. It's exactly what I will be doing however I was hoping that someone had access to the wiring/colour info already so that I could save myself tracing the wires back behind the dash from the doors. And minimising the risk of tapping into the wrong wires!
Looks like I'll have to do it the hard way then :) I'll be sure to post up my progress.
yea definitely, I will be doing the same shortly
I want to figure out a way to program the 3.5 inch display, because when I replace my stereo, it will be useless.
So i see some models come with subwoofers and was wondering if there is a subwoofer connection on the back somewhere
1 - 14 of 14 Posts
