1 - 1 of 1 Posts
I found a simple solution to secure the console if you happen to break the front support tabs.
Using a small drill bit, drill a hole on the console, centerline in the front.
https://flic.kr/p/rfpXVP
Then, open the shade on the roof. Slightly pull down the headliner and drill another centerline hole on the black plastic cross member.
Take a piece of #18 or #20 solid wire, tie one end to the console, thread the other end through the second hole you drilled, pull it up tight and tie it off.
1 - 1 of 1 Posts
