Hi,
I need to replace the timing cover on my girlfriends 2012 Focus SE. Can I simply unbolt the harmonic balance and accessories, replace cover and then reinstall the balancer and accessories?
Reason I ask is I see that a special timing pin (OTC 303-307) is needed to set motor at TDC when doing a timing belt swap but if I dont rotate the crank when changing the cover, do I need to follow that procedure?
Thanks for any help, hopefully it is an easy swap and not a extensive process.
