I got dirty gas in my gas tank. I thought everything was okay but now I'm 250 miles away from home and its been acting up. After 90 minutes of driving it started to stumble and lose power. I pulled over on the side of the road and waited 5 minutes and then it drove fine for another hour and then did the same thing. I've done this several times now and the problem does not seem to be getting worse. it happens when I'm using the fuel pump most like passing someone or going uphill.
I'm afraid that my fuel filter is clogged up but this car doesn't have a separate fuel filter from what I understand and it's part of the fuel pump. It's kind of hard to tell but I think it's actually getting better the more fresh gas I add.
I'll probably be able to limp the car home tomorrow but what would you guys recommend I do when I get it home? Should I put in a new fuel pump? It seems to work fine until it gets ooverheated. Ive read about cutting a hole under the back seat to get to the pump easier but this seems kind of sketchy to me with a grinder and gasoline.
it seems like it might be a hard problem to isolate.
Any ideas would be very much appreciated. Thank you.
